热搜: ROHM 模拟 车载
查看: 1789|回复: 2
esp8266一键配网
精华
新手上路
最后登录
2019-12-3
发表于 2019-12-3 14:52:14 | 显示全部楼层 |阅读模式
#include <ESP8266WiFiMulti.h>
#include <ESP8266WiFi.h>
#include <ESPHTTPClient.h>
#include <JsonListener.h>
// time
#include <time.h>                       // time() ctime()
#include <sys/time.h>                   // struct timeval
#include <coredecls.h>                  // settimeofday_cb()
#include "SSD1306Wire.h"
#include "OLEDDisplayUi.h"
#include "Wire.h"
#include "OpenWeatherMapCurrent.h"
#include "OpenWeatherMapForecast.h"
#include "WeatherStationFonts.h"
#include "WeatherStationImages.h"
ESP8266WiFiMulti wifiMulti;
#define TZ              7      // (utc+) TZ in hours
#define DST_MN          60      // use 60mn for summer time in some countries
// Display Settings
const int I2C_DISPLAY_ADDRESS = 0x3c;
const int SDA_PIN = 0;
const int SDC_PIN = 2;
SSD1306Wire     display(I2C_DISPLAY_ADDRESS, SDA_PIN, SDC_PIN);
// Setup
const int UPDATE_INTERVAL_SECS = 20 * 60; //每20分钟更新一次
String OPEN_WEATHER_MAP_APP_ID = "7ff9d5162ef11a6625b22343e0a78426";//打开天气地图应用程序ID
String OPEN_WEATHER_MAP_LOCATION_ID = "1809461";//武汉:1791247 贵阳:1809461 镇远:1811722//打开天气地图位置ID
String OPEN_WEATHER_MAP_LANGUAGE = "zh_cn";//打开天气地图语言
const uint8_t MAX_FORECASTS = 4;
const boolean IS_METRIC = true;
// Adjust according to your language
const String WDAY_NAMES[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};//星期
const String MONTH_NAMES[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};//月份
OLEDDisplayUi   ui( &display );
OpenWeatherMapCurrentData currentWeather;
OpenWeatherMapCurrent currentWeatherClient;
OpenWeatherMapForecastData forecasts[MAX_FORECASTS];
OpenWeatherMapForecast forecastClient;
#define TZ_MN           ((TZ)*60)
#define TZ_SEC          ((TZ)*3600)
#define DST_SEC         ((DST_MN)*60)
time_t now;
// flag changed in the ticker function every 10 minutes
bool readyForWeatherUpdate = false;
String lastUpdate = "--";
long timeSinceLastWUpdate = 0;
//declaring prototypes
void drawProgress(OLEDDisplay *display, int percentage, String label);
void updateData(OLEDDisplay *display);
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state);
void setReadyForWeatherUpdate();
FrameCallback frames[] = { drawDateTime, drawCurrentWeather, drawForecast };
int numberOfFrames = 3;
OverlayCallback overlays[] = { drawHeaderOverlay };
int numberOfOverlays = 1;
void smartConfig()
  WiFi.mode(WIFI_STA);
  Serial.println("\r\nWait for Smartconfig");
  WiFi.beginSmartConfig();
  int counter = 0;
  while(!WiFi.smartConfigDone())
    Serial.print(".");
    delay(500);
    display.clear();
    display.drawString(64, 10, "Connecting to WiFi");
    display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
    display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
    display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
    display.display();
    counter++;
    Serial.println("SmartConfig Success");
    Serial.printf("SSID:%s\r\n",WiFi.SSID().c_str());
    Serial.printf("PSW:%s\r\n",WiFi.psk().c_str());
    wifiMulti.addAP(WiFi.SSID().c_str(),WiFi.psk().c_str());
void setup() {
  // put your setup code here, to run once:
  Serial.begin(115200);
  delay(1000);
  Serial.println(" ");
  Serial.println("Start module");
  //初始化显示
  display.init();
  display.clear();
  display.display();
  //display.flipScreenVertically();
  display.setFont(ArialMT_Plain_10);//设置字体
  display.setTextAlignment(TEXT_ALIGN_CENTER);//设置文本对齐
  display.setContrast(255);//设置对比度
  wifiMulti.run();
  delay(1000);
  if(wifiMulti.run()==WL_CONNECTED)
    Serial.println("WiFi connected");
    Serial.println("IP address:");
    Serial.println(WiFi.localIP());
   else if(wifiMulti.run()!=WL_CONNECTED)
    Serial.println("WiFi not connected!");
    smartConfig();
    // 从网络时间服务获取时间
  configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
  ui.setTargetFPS(30);//设置目标FPS
  ui.setActiveSymbol(activeSymbole);//设置活动符号
  ui.setInactiveSymbol(inactiveSymbole);//设置不活动符号
  // You can change this to
  // TOP, LEFT, BOTTOM, RIGHT
  //您可以将此更改为
//上,左,下,右
  ui.setIndicatorPosition(BOTTOM);//定位  底部
  // 定义第一帧在栏中的位置。
  ui.setIndicatorDirection(LEFT_RIGHT);//左边
  //您可以更改使用的转换
  // SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
  ui.setFrameAnimation(SLIDE_LEFT);//设置帧动画  左滑道
  ui.setFrames(frames, numberOfFrames);//设置帧
  ui.setOverlays(overlays, numberOfOverlays);//设置覆盖
  // Inital UI takes care of initalising the display too.
  ui.init();
  Serial.println("");
    updateData(&display);
void loop() {
  if (millis() - timeSinceLastWUpdate > (1000L*UPDATE_INTERVAL_SECS)) {//上次更新时间 - 更新间隔秒
    setReadyForWeatherUpdate();//准备设置天气预报
    timeSinceLastWUpdate = millis();
  if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {//已准备就绪   并且框架==固定的
  int remainingTimeBudget = ui.update();//剩余时间预算
  if (remainingTimeBudget > 0) {
    // You can do some work here
    // Don't do stuff if you are below your
    // time budget.
    delay(remainingTimeBudget);
void drawProgress(OLEDDisplay *display, int percentage, String label) {//进度条
  display->clear();
  display->setTextAlignment(TEXT_ALIGN_CENTER);//设置文本对齐方式
  display->setFont(ArialMT_Plain_10);//设置字体
  display->drawString(64, 10, label);//标签
  display->drawProgressBar(2, 28, 124, 10, percentage);//百分比
  display->display();
void updateData(OLEDDisplay *display) {
  drawProgress(display, 10, "Updating time...");
  drawProgress(display, 30, "Updating weather...");
  currentWeatherClient.setMetric(IS_METRIC);
  currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  currentWeatherClient.updateCurrentById(&currentWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID);
  drawProgress(display, 50, "Updating forecasts...");
  forecastClient.setMetric(IS_METRIC);
  forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  uint8_t allowedHours[] = {12};
  forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
  forecastClient.updateForecastsById(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID, MAX_FORECASTS);
  drawProgress(display, 100, "Done...");
  delay(1000);
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  now = time(nullptr);
  struct tm* timeInfo;
  timeInfo = localtime(&now);
  char buff[16];
  String date = WDAY_NAMES[timeInfo->tm_wday];
  sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon+1, timeInfo->tm_year + 1900);
  display->drawString(64 + x, 5 + y, String(buff));
  display->setFont(ArialMT_Plain_24);
  sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
  display->drawString(64 + x, 15 + y, String(buff));
  display->setTextAlignment(TEXT_ALIGN_LEFT);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  display->drawString(64 + x, 38 + y, currentWeather.description);
  String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
  display->drawString(60 + x, 5 + y, temp);
  display->setFont(Meteocons_Plain_36);
  display->drawString(32 + x, 0 + y, currentWeather.iconMeteoCon);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  drawForecastDetails(display, x, y, 0);
  drawForecastDetails(display, x + 44, y, 1);
  drawForecastDetails(display, x + 88, y, 2);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
  time_t observationTimestamp = forecasts[dayIndex].observationTime;
  timeInfo = localtime(&observationTimestamp);
  display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
  display->setFont(Meteocons_Plain_21);
  display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
  String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
  display->drawString(x + 20, y + 34, temp);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
  char buff[14];
  sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
  display->setColor(WHITE);
  display->drawString(0, 54, String(buff));
  display->setTextAlignment(TEXT_ALIGN_RIGHT);
  display->drawString(128, 54, temp);
  display->drawHorizontalLine(0, 52, 128);
void setReadyForWeatherUpdate() {
  Serial.println("Setting readyForUpdate to true");
  readyForWeatherUpdate = true;
精华
最后登录
2024-4-24
发表于 2019-12-3 15:36:52 | 显示全部楼层
我还是喜欢乐鑫的SDK
精华
金牌会员
最后登录
2024-4-24
发表于 2020-3-11 01:16:01 | 显示全部楼层
感谢分享
Archiver|手机版|小黑屋|罗姆半导体技术社区
GMT+8, 2024-4-25 04:33 , Processed in 0.088338 second(s), 13 queries , MemCache On.
